front sprocket
  • sailfish
    • Sep 2010
    • 175
    front sprocket
    on the front sprocket on and 1983 shovel the nut is right handed threads ?
  • diesel55
    • Jul 2011
    • 262
    shovel
    yes they are.
    • sailfish
      • Sep 2010
      • 175
      thanks thats what i thought its hard to get off
        • 5946
        Use a hand held impact driver to remove it.
        • PRG
          • Nov 2006
          • 612
          Howdy sir,
          If your machine is a solid mount 4 speed you can benefit immeasurably from installing a James Gaskets Super Nut. It contains a double lip seal on the face of the nut with a machined groove on the backside for an o-ring. This completely eliminates trans oil leaking from between the trans mainshaft and the sprocket driver sleeve, even on machines with the bushing knackered from running the final drive chain too tight. I run them on both my Shovels and even my 41 for those Knuck fans looking to stem the tide of oil laying under their primaries.
          Cheerio,
          Peter
          #6510
          • diesel55
            • Jul 2011
            • 262
            he said front sprocket not intermedite.thank you
            • rousseau
              hillbilly member
              • Jul 2003
              • 261
              Are you calling the compensator the front sprocket??
