I have a 68 flh.The turn signal on the left blinks super slow the one on the right does not blink but you can hear the flasher blinking real fast. Any suggestions?
68 FLH turn signal
I know this is somewhat belated, but you should check the bulb sockets for any corrosion and also verify you have a clean ground at each. Also check the switch on the handlebars and all the connections on each end of those wires.Lonnie Campbell #9908
South Cackalackey, U.S. of A.
For the blinker that does not flash you have a broken wire leading to either the front or rear or both for that matter on the side that does not flash. Check wiring under rear fender which seems to be a favorite place for brakes. You could have a bad swich too. See what's happening on your terminal board inside headlight.
