Bike runs fine,except when im downshifting to 2nd it just dies. I turn ingnition off and then back on. one kick,fires right up.idles great. next stopsign it dies. ran find before any ideas?
1971 superglide,dies when decelerating
The ignition switch could do this also. They can be touchy if worn, or the wires are not right and tight.
Mike
you guys rock. took me right to the problem....sort of... after replacing the springs on the weights and points and condenser..still had intermittent fire... I used a test light to find that the dam connector on the wire to the points was wrong and not making contact.
replaced it. She runs flawlessly. Thanks for the help Brad
