1950 panhead rocker covers question
  • Glenn
    Member to Remember
    • May 2007
    • 403
    I have the polished stainless rocker covers for my 1950 pan, the question is did a d ring go on the factory 1950 if so was it the thick or thin and what screws or bolts went with it
    tia
    Moose
    aka Glenn
    The originals were electro-polished. Not polished with a wheel and compound. There were no "D" rings and Phillips head screws held them down.
    • Glenn
      Member to Remember
      • May 2007
      • 403
      what is electro polishing and who does it now a days and how do I do that to look original ? and I assume that would apply for the front fork lowers and brake backing plate for the 1950 pan Delux Solo group options
      Moose
      aka Glenn
        You will have to let your fingers do the walking to find a plating shop that does electro polishing in your hood. The front brake backing plate is bare die cast aluminum and was not electro polished or polished.
        • Glenn
          Member to Remember
          • May 2007
          • 403
          thanks chris
          reading palmers book it said front backing plate on the delux was polished for a 50 pan
          Moose
          aka Glenn
