hydraulic lifters or oil pump
  • 58pan
    • Apr 2011
    • 16
    have a 58 pan that I rebuilt and it seems like a new engine when it starts but when it gets warmed up I can hear the lifters making a lot of racket I didn't check the lifter blocks to good and was wondering if that could be the problem or would it be the oil pump?
  • cdndewey
    • Jan 2005
    • 438
    Did you install the lifters correctly? The holes/flat sides have to be on the inside facing each other.
      • 8247
      58Pan!
      Can we assume you have OEM-style hydraulic lifters and OEM cam?
      • 58pan
        • Apr 2011
        • 16
        not sure I did it was 8 years ago but I did check the oil pressure and it was 18 at idle and ended up puting solids in for now but thanks for the info
