Question on Winter Windshield Acessory
  • rbenash
    • Jul 2001
    • 643
    Hey folks - I have an NOS Winter-Summer Combination Windshield Kit. Page 14/15 in the 1965 Accessory Catalog. It's an apron with a pair of brackets to be used along with the 'Glide windshield or the Sportster/Model K windshield. 57990-60B
    I have NOS set of splash shields to go with it too.
    The pair of brackets still has the orange/black bar logo still on it. There's no hardware or instructions.
    Does anyone have a copy of the instructions or a photo of one mounted on a late Duo Glide or early Shovel? Would like to see how these were attached to the windshield. Any info would be helpful.
    Should be able to figure it out but don't have the bike here.
    Ray
    AMCA #7140
    • 4791
    Ray,
    They are pretty straightforward. The wing brackets mount to the windshield vertical supports (the curved ones) with the extra long bolts supplied in the kit. There is a second bolt on the top support that replaces ti inboard one of the clip bolts ( the stainless clip that wraps around the upper and lower shield at the joint). The lower bolt is in the end of the curved piece of the wing and bottom of the windshield bracket. Is the apron attacked to the brackets? The clips that look like cable clips go on the outside of the fabric on the front. I have one with the bracket attached to it if you need pics. not mounted on a bike.
    Robbie
    • rbenash
      • Jul 2001
      • 643
      Hi Robbie - thanks for the detail. I just have the brackets and the apron. None of the hardware or the instructions. The brackets are not permanently attached to the apron, brackets are two separate pieces. There's a pocket on each side of the apron that I think might be for the corners of the brackets to slide into once the set is mounted to the windshield.
      Ray
      AMCA #7140
      • cdndewey
        • Jan 2005
        • 438
        Ray..PM me your e-mail address and I will scan and send you a copy of the installation instructions for the winter windshield.
        • rbenash
          • Jul 2001
          • 643
          cdndewey - PM sent, thanks!!!!
          Ray
          AMCA #7140
