cadmium
  • portagepan
    • Feb 2006
    • 580
    cadmium
    What would be the correct cad plating on the
    Harley Davidson carrier plates for swing arm bubble bag mounts, '60's fiberglass bag mounts, and cad plated star hub covers? I mean, is it bright silver, gray dull, or what? Thanks.
    Mike
    Simply cadmium plating. The finish will vary on piece to piece in any batch you have done. Don't sweat it. The factory didn't.
    • upsrod
      • Feb 2010
      • 320
      No cad on star hub covers!
      • portagepan
        • Feb 2006
        • 580
        Thanks Chris, that ios what I thought, though most seem to be a clear. And Rod, what was on the star hub covers. I have seen them that were painted black, of course, but were there any other finishes used? Thanks. Mike
          I always thought that star covers were parkerized.
          • upsrod
            • Feb 2010
            • 320
            They are, the inner, the outer, the lock washers and the screws.
            • portagepan
              • Feb 2006
              • 580
              But I have seen them painted just like the hubs, black. Man, that stuff was put on to stay!
              Mike
                Every star I've seen, is parkerized. Hub painted black and grease nipple cad at least on the later ones.1940 up. I can't say that about the earlier grease fitting. Bob L
                  • 8247
                  The majority of "stars" were a light gray parkerizing.
                  If all the parkerizing on an H-D machine matches, it should be considered a fault.
                    Early Knuck's, 45's, and UL's had cad plated star covers.
                      • 4791
                      And had two slots in them for the 45 rear wheel speedo drive!
                      Robbie
