1965 paint lay-out
  • portagepan
    • Feb 2006
    • 580
    Those lines on the front of the tank definitely do not look right ro me. I'm just sayin'.
    Mike
    • rbenash
      • Jul 2001
      • 643
      Yes, It's the angel of view of the camera as well as the angle of the tanks in the stands in those photos. You really need to see the originals and these side by side and from the same angle, but these were the only ones I had handy.
      Ray
      AMCA #7140
      • rbenash
        • Jul 2001
        • 643
        Here's another photo of the originals still on the bike looking at the back at an angle. Looking close you can see the lines mismatch on the right tank (looks a tad lower):
        Ray
        AMCA #7140
        • kg993
          • 263
          I never actually noticed the lines being different till I started measuring. I laid mine out the same way (with dividers),putting little 1/2 " pieces of tape down as references for the fine line tape. I thought the differences in the origional paint I was copying was just a one time deal.
          Kerry AMCA # 15911
          • Underdoggie
            • Mar 2009
            • 100
            I took a picture this morning from the same point of view as Ray's and they look pretty close to me, I wonder if the slight mismatch in the back is from the mounting tabs on the frame.
            I found this picture I took last year when I had the front end off, the lower part of the triple tree is in the way but they seem like to me they would come pretty close to lining up with the right side in the picture maybe higher, the you judge
            John Underwood
            AMCA#14400
            Central Illinois
            • rbenash
              • Jul 2001
              • 643
              Yeah, I hear you John. But thing is on mine the tops of the tanks were level when mounted where that rubber filler fits between the tanks and at the fronts. Also on my originals it was measurable when he was working with the dividers to do the copy on the duplicate set. Based on your under seat photo doesn't really look like yours are really off like mine were. Probably depends who was doing the painting the day they were done
              Ray
              AMCA #7140
              • Underdoggie
                • Mar 2009
                • 100
                Yeah, they were breaking in a new paint apprentice that day and when the boss asked how long he had been on the job he said "tirteen mora day be 2 week"
                John Underwood
                AMCA#14400
                Central Illinois
                • rbenash
                  • Jul 2001
                  • 643
                  Here's another photo of the repaint that was measured exactly using multipoint divider measurements from the originals. Better view of where the curve actually starts. Also didn't forget about posting some photos of the originals. Try to get them posted this week.
                  https://
                  https://
                  https://
                  Ray
                  AMCA #7140
                  • brian
                    • Oct 2010
                    • 34
                    Do you have paint codes for holiday red or where did you get the paint.
                      There have never been any factory paint codes for H-D paint.
                      • rbenash
                        • Jul 2001
                        • 643
                        Chris is right. No factory formulas that I'm aware of.
                        That said there are a couple places that are selling match paints. In my case I was hesitant to go that route. Specifically because of the Hi Fi Blue. Over the last 10 years or so I've seen a number of Hi Fi Blue repaints, and only a couple got the blue right IMHO. Can't say why but they just looked off. Let alone getting the white placed right and the curve correct.
                        The paint work on my bike was done by Paul Freibus at American Cycle Fab. He mixed all the paints himself. He makes his own silver base using actual vintage silver powder. He mixes his own birch white. For the blue he took my originals, and did his own match and mix to the unfaded areas. He started with his own dyes and worked to the point that his match looked exactly the same under all light conditions. Then he called me to take a run up and we went through the process of looking at the sample along side the originals in all different light conditions. Then he painted.
                        Ray
                        AMCA #7140
                          #27
                          I have a can of that Silver Base Coat.
                            #28
                            And a few other colors.
                              #29
                              Here is a list of the H-D paints I had 20 years ago. I haven't added any of my acquisitions to the list since then.
                              1/4 PINT
                              1160134A Airway Blue
                              9873*-51 98600-V Atomic Blue or Rio Blue
                              98600-AO Aztec Brown
                              Black Cylinder Coating
                              98600-AV Birch White
                              98600-AE Bronco Bronze Metallic
                              11629-37A Bronze Brown
                              94909-49 98600-AA Burgundy
                              ` 98600-BB Calypso Red
                              98600-AK Cavalier Brown (1)
                              98600-AP Champion Yellow
                              1162*-X 98600-B Clear Varnish
                              11628-35A 90600-Q Clipper Blue
                              11602-41A 98600-K Cruiser Green
                              98600-CE Crystal Blue (1)
                              98600-AL Daytona Ivory
                              11628-37A Delphine Blue
                              11615-36A Dusk Gray
                              98600-AR Flamboyant Metallic Green (2)
                              11626-40 98600-F Flight Red
                              98600-AL Forest Green
                              98600-AH Glacier Blue
                              98600-AG Glamour Green
                              98600-BN Granada Green
                              98665-49 Heat resistant Black (6)
                              98660-49 9491*-49 Heat Restraint Silver (1)
                              98600-AX High Fire Red (1)
                              98600-CC Holiday Red
                              98600-AN Hollywood Green
                              98600-CA Horizon Blue
                              98600-CD Indigo Metallic (5)
                              98675-35 Leather Lacquer Black
                              11655-41A Leather Lacquer Brown
                              98600-AF Marine Blue Metallic (1)
                              11614-XA 98600-Y Maroon
                              9874*-51 98600-W Metallic Blue
                              94900-49 98600-L Metallic Congo Green
                              98600-AZ Midnight Blue
                              98600-BA Nugget Gold
                              9491*-49 98600-T Peacock Blue
                              98600-AJ Pepper Red
                              98660-51 98600-H Persian Red
                              11612-XA 98600-O Police Blue
                              11615-41A Police Gray
                              11617-X 98600-A Primer
                              11629-35 Regent Brown
                              9873*-51 98600-V Rio Blue or Atomic Blue
                              98600-U 98600-U Riviera Blue
                              11601-36A Royal Buff
                              98600-BC Saber Gray Metallic
                              98600-BL Scooter Blue (4)
                              98600-AW Skyline Blue
                              11601-41A 98600-R Skyway Blue (1)
                              98600-AC Spring Green (1)
                              98600-BL Strato Blue
                              98600-AU Sun Gold (1)
                              98600-AS Tangerine
                              98600-BW Tango Red
                              98600-BD Tropical Coral (2)
                              98600-AD Tropical Green
                              Varnish
                              11646-XA Verdant Green
                              11648-X 98600-D White (6)
                              1/2 Pint
                              94941-50 1950 Metallic Green
                              98691-51 1951 Metallic Green
                              11601-34 98601-P Airway Blue
                              11628-35 98601-Q Clipper Blue
                              98601-AL Forest Green
                              98601-AH Glacier Blue
                              98601-AN Hollywood Green
                              98601-AF Marine Blue Metallic
                              94931-50 Ruby Red
                              98601-E Silver
                              94926-50 98601-AB Sportsmans Yellow (1)
                              99703-55 Tire Black
                              98601-AD Tropical Green
                              1 Pint
                              ?199 Blue Diamond
                              98602-AL Forest Green
                              98602-AG Glamour Green
                              98602-AZ Midnight Blue
                              98602-AC Spring Green
                              98602-AS Tangerine
                              Quart
                              98610-B Aluminum Undercoat (1)
                              98603-AV Birch White
                              98603-AE Bronco Bronze Metallic
                              Classic Creme
                              98610-E Hi-Fi Red
                              98603-AX High Fire Red
                              Holiday Red
                              90603-AZ Midnight Blue
                              98603-A Primer
                              98603-DC Sunburst Blue
                              98603-DM Sunburst Turquoise
                              98603-DU Vivid Brown (1)
                              15-3/4 oz. Spray
                              98607- Birch White
                              98607- Brilliant Red
                              98706-EW Classic Tan
                              98607-BT Hi-Fi Purple
                              98607-DB Sunburst Burgundy (1)
                              98607-CN Sun Gold
                              98607-DR Sunburst Orange
                              98607- Sunburst Red (1)
                              98607-CA Sparkling Burgundy
                              98607- Sparkling Emerald (1)
                              98607-CS Sparkling Green
                              98607-CW Sparkling Red (3)
                              98607-D White (5)
                              Touch Up Bottles
                              98600-ED Artic White
                              98600-ER Black Cherry
                              98600-DY Brilliant Red
                              98600-EP Chestnut Brown
                              98600-FY Chocolate Brown
                              98600-EN Concord Blue
                              98600-FN Dark Carmine
                              98600-FZ Emerald Green Metallic
                              98600-EL Hi-Temp Gray, Mtl.
                              98600-FM Light Red
                              98600-GA Non-Metallic Red
                              98600-FT Olive
                              98600-FU Orange
                              98600-GB Pewter Metallic
                              98600-GR Rose Metallic
                              • rbenash
                                • Jul 2001
                                • 643
                                #30
                                Nice collection you've got there Chris. Peacock blue is one of my favorites. Saw one of the early Hydra Glides in the color, very nice. That silver hi heat is getting hard to find. Had a can that we used for my bike. Haven't seen any around since I bought that can about 5-6 years ago. Wold be nice to have another for spare/touch up. Have three of the glass jars of the baking enamel in Hi Fi blue, but they are clay balls though. Bar and shield logo. They were never opened. It was good enough to get a starting point on what color dye to start working with to come up with the right mix.
                                Ray
                                AMCA #7140
