62 fl windshield
  • hennigan62
    • Sep 2010
    • 140
    62 fl windshield
    Does anyone have a suggestion what to use to clean and buff an original windshield. In good shape, just needs cleaned up.
  • D.A.Bagin
    • Jan 2008
    • 595
    I have used Meguiar's Plastix I believe it is called on my 57 and my Indian with good success. Try on a small area first.
      • 2044
      on really yellowed windshields spray ez off oven cleaner accross the top and progress down the shield, use clean rag, wipe straight down using clean rags each wipe --repeat ---rinse with cold water.---learned this 25 years ago at Davenport from plastics specialist. P.S.-move fast
        • 2044
        I fogot to add- use "Jell Gloss" to polish and wax after using ez off
        • ManPan
          • Jun 2009
          • 40
          Yep, Move fast and accurate...it does work, e-z-off,that is...Keep the residue off anything you don't want @#%$&^ up....old towels and such..
          Baker, William, R......
          AMCA# 15164......"50" FL, "34" VLD....
