Correct Direction & Mounting for a Timer Control Wire on a 58 DuoGlide
  • 58Panheadfan
    • Dec 2006
    • 33
    Hello
    I'm in process to directioning & mounting a Timer Control Wire on a 58 DuoGlide. There are some clips and clamps (see pics).
    56626-49 Clip Spark Control Coil
    56620-50 (9957) Clip Spark Control Coil
    4726-37 (9971) Timer Wire to Crankcase
    I need some help (pics or description):
    - how/which Cable/Clip/Clamp are mounted correctly / which hardware is used to mount clips/clamps
    - how cable is installed (routing)...
    Bruce Palmer's Book doesn't reflect this chapter for 58 year production.
    Thank you, Harry AMCA # 8968
