Tail Light Wiring Routing
  • MWFAH52
    First, I can't believe no one has posted to the Panhead area as yet. Well, someone has to go first.
    My question - I can't for the life of me remember the routing for the wiiring coming from the tail light (where it exits the rear fender) and goes to the frame terminal block on my '60 FLH. Does it run over or under the oil tank? I'm in the process of installing new wiring and am stumped. The bike has been partially disassembled for a year and I have just flat forgotten this detail.
    Thanks to anyone that can help.
    MWF
    wiring
    Over the tank, along the frame. It is held there by a parkerized clip (OEM 9983, I think...)
    If you choose an aftermarket 'custom' exhaust, you will still want a system that runs between the frame and motor as the original "S" pipe does. Otherwise, cornering makes sparks.
    • MWFAH52
      Thanks! That is what I remembered but I wanted to make sure.
      MWF
