Hydra glide lower legs
  • DANPATCH
    • Apr 2009
    • 313
    I have two styles of lower legs . one has the boss for the drain plug at the bottom on both sides .The boss on the front side is not drilled. The other has the boss on the back side and is drilled . The front of the leg just has a large rib .The one with out the boss in the front is this 1950-54 ???. Thanks
