Hi folks does anybody know of a shop that can restore my pan lower legs (fill in a couple deep scrapes and polish,repair stripped fender bolt holes and possibly replace bushings?) any help would be greatly appreciated! Also looking for cylinders with good fins that have a few bores left for my 55 pan. It's not gonna be a show bike but still want it to look sharp! Thanks Jim
Hydra glide leg restoration and need pan cylinders
Give Tom Shaw at Creekside Machine and Welding a call. He repaired some broken fins on the cylinders on my 49 as well as some case repair. Very pleased with the quality of his work as well as turn-around timeOriginally posted by j**r**m View PostThanks for the info guys I just picked up a set that are 10 over - just gotta find someone to replace the 2 broke off fins on each cylinder now. Thanks again, Jim.
I also have a set of early HydraGlide fork sliders with some serious dings in them. Looks like some drunken gorilla tried to knock the bushing loose-- from the outside. (rolls eyes). I have since picked up a much nicer set, but would certainly like to sweeten up my old set. If you make in any progress towards that end, please advise?Originally posted by j**r**m View PostHi folks does anybody know of a shop that can restore my pan lower legs (fill in a couple deep scrapes and polish,repair stripped fender bolt holes and possibly replace bushings?) any help would be greatly appreciated! Also looking for cylinders with good fins that have a few bores left for my 55 pan. It's not gonna be a show bike but still want it to look sharp! Thanks Jim
Also, the stripped threads at fender mount is not that big of a deal--- Helicoil (or other thread repair) is a perfectly acceptable and sound repair, and if installed properly is perhaps better than new. A more serious defect would be stripped drain plug threads; Helicoil is not leak-proof, while I've been told that TimeSert is.
