48fl Wiring routing type queastion.
  • 48fl Wiring routing type queastion.
    Good afternoon lads, Trying to figure out a wire routing problem on my 48FL. The bike in the picture below was and original paint at Oley 09. It is fitted with side car hardware. If you look at the center down tube were the retaining clip is, you’ll see a single wire next to the oil/brake switch wire. Is this the wire that would feed the side car fender light, if it’s not then what is it for? Also the circuit breaker wire, was this routed around the center tube or in front of it? Thanks in advance, Bob L
    Bob, Here is a pic of an original 48, not a side hack unit though. Don't know what your extra wire is for.
    Brian Howard AMCA#5866
