Cylinder Head Date Code
  • partshunt
    • 285
    I have a 1948 Front head off a panhead with a date code A-8. would that break down to indicate Jan 1948? If not, otherwise, how does one decifer the code?...thanks for any & all replies...Joe
    Joe AMCA# 3435
    That's what it be!
    • partshunt
      • 285
      Thank you very much. Looks Like I may have guesed it right for a change lol....Joe
      Joe AMCA# 3435
      • partshunt
        • 285
        I have another 48 pan front head with a date code L-7. That must be Dec 1947. Built for the 1948 run. Are they common?...Joe
        Joe AMCA# 3435
          • 2024
          Thats probably the earliest series of the 48 head. It should have a boss with a screw in it directly top center. Jerry
          • partshunt
            • 285
            Jerry, I looked it over, dont see the screw head and boss. Exactly where do I check?...Joe
            Joe AMCA# 3435
            • Re-cycleInc
              • May 2009
              • 43
              I thought the "I" was skipped so it wouldn't be confused with the number 1 so the L code should equal November, right?
              A= January
              B= February
              C= March
              D= April
              E= May
              F= June
              G= July
              H= August
              I= skipped
              J= September
              K=October
              L=November
              M=December
              Scott
              AMCA# 13993
              • partshunt
                • 285
                Certaintly Scott- I forgot about the letter "I". I may have read that somewhere. Palmers book possibly and it slipped my mind but I do think now you are correct on that one.........Joe
                Joe AMCA# 3435
                  The screw block was very early. By December they had been making '48 heads for five or six months. The cast in dam was in use by then.
