cam cover help
  • whtaxl
    • Mar 2009
    • 34
    cam cover help
    Can anyone recommend a service to completly recondition 58-62 style cam cover? need new locating pins installed, replace an oil tube, texture etc.,
    Ran
    The locating pins are in the crank case, not the gear cover. I am confused by oil line. What exactly are you talking about?
    • whtaxl
      • Mar 2009
      • 34
      Hi Chris, in the crank case its the tube is the one that goes right above the breather screen and separator (25279-36, 25275-36). There is a mating tube penetrating from the cam cover to fit in or over that tube. In my case it is broken and needs replacement, along with other issues that I need fixed before installation.
      Ran
        Sounds like you would be better off replacing it.
