'64 pan frame measurement
  • DanMargolien
    Restoring a frame, and need to replace the pipe stub on the lower right side- believe it is for a jack?
    Would appreciate a measurement of length from frame rail, the diameter of the hole in the bottom, and where it is located from the end of the stub.
