48 Neck!
    48 Neck!
    Guys I came across this on Fleese-Bay http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT. Every 48 neck I’ve ever seen had the damper pin boss on the casting. My 48 has a 7500 number and the boss is there. It’s not drilled but it’s there. Was there any 48 without the boss? Nothing for nothing, I stared at this pic for twenty minutes and it sure looks like the speedo mount is welded on. I posted to pictures below. The first is of the e-bay thing. The other was from some guy in California that now driving around in a big white truck. If this is junk. Then the high bidder is sure going to be pissed. Why not just buy the one from Assi Steve. Bob L
    • 2024
    Robert
    To me it looks like the dash mount has been reattached - that would explain it. Jerry
    • Re-cycleInc
      • May 2009
      • 43
      I'm with you Rob - I thought the '48s all had the unmachined dampener in the casting. My '48 has a cobbled speedo/tank mount so I found this item on eBay a little while ago. I figured $75 was worth the gamble and it even has the stamps in it. I had a 45" frame repaired a while back and the guy had to grind a repop mount and then build it up with braze. I'm hoping this setup is a little easier.
      Scott
      AMCA# 13993
