Front Brake Problem
  • Mark M
    • Jan 2008
    • 10
    Front Brake Problem
    I have a 48 pan with a repo fron end. I am having trouble getting the front brake shoes to give me any kind of stopping. The brake cam is adjusted at about a 30 degree angle to the make to make intial contact with the drum and doesn leave much for friction. the obvious problem would seem that the shoes are worn but they are brand new from v-twin. do I have the correct shoes installed? or is this just another v-twin it doesn't match problem? I can email you a photo, file is too large to post.
  • flthead
    • Dec 2003
    • 412
    ching chang brake shoe fix
    need to take a square shim of sheet metal and tack weld it to brake shoe end that rides on cam. this will shim the shoes out for better contact surface . been there done that
    • Ohio-Rider
      Supporting Member
      • 852
      None of the springer front brakes have much stopping power. If you get it to hold you stationary on hill then I’d say you have it set up about as good as its going to get. With out going to the evil disc brake setup, you’ll just have to adjust your riding style to your front brakes stopping power.
      Steve
      AMCA #7300
      • scoot
        • Aug 2008
        • 44
        I had my pads re-lined at Vintage Brake. It made a huge difference in my stopping power. The front brake was useless, however after the reline, I have to remember not to grab too much. It takes about a half second for them to heat up and, then they get real sticky real fast. I have the VB3000 in the back and something stickier up front, don’t remember the lining.
