Footlever and Footboard
  • Pandit
    • Mar 2008
    • 34
    On my 61 Duoglide is the footlever down on the footboard. Is that correct? Has somone a pic with the correct position?
    Thank you
    Roland
    #13580
  • Mr. Big
    • Feb 2010
    • 130
    Toe down is engaged and heel back is disengaged. Is that what you're asking?
    Oops, now I see whacha askin. Does it not engage/disengage correctly?
    47 WL
    51 Ls Sidecar
    03 FLHT
    http://www.gouldingsidecars.com
      How about just adjusting the linkage?
      • Pandit
        • Mar 2008
        • 34
        The pedal goes down to the footboard and damages the rubber. The likage is correct and engage/disangage is also correct. Before I had a rubber on the pedal, now it is without. Goes the pedal as fare as the spring pulls?
        • bmh
          • Feb 2007
          • 901
          Is the push rod adjustment at the center of the clutch hub set correctly? That would affect the position of the release lever and thereby the foot pedal.
          Brian Howard AMCA#5866
          • Pandit
            • Mar 2008
            • 34
            Has someone a pic of the original footboard and clutchlever?
            Thank you
            #13580
              • 4791
              Pandit,
              Your footboard stud is not correct. I am not sure on your '61 but on mine the front of the footlever has a short ear on it that hits the footboard mounting stud before the pedal hits the footboard.
              Robbie
              • flat-happy
                • May 2009
                • 543
                yup the one you have is a right front duoglide with a couple of spacers. i can't get a pic to you right now but he is correct---the metal part of the pedal contacts the stud before the lever touches the pad
