Panhead tappet block
  • rick anderson
    • Dec 2006
    • 63
    I have a cast iron front tappet block that does not have an oil feed hole. Did Harley-Davidson ever use these?
    Rick
    Rick Anderson
  • koanes
    • Apr 2003
    • 656
    I'd love to see this mystery solved. I have never seen a cast iron rear. A friend sent me a picture of his early 48 motor and it has iron front and aluminum rear.
    Kyle Oanes AMCA # 3046
      • 2019
      I too have at least 3 front and notta rear. Kyle and I have talked about these cast ones that were cast in the image of the aluminum ones but have not found an answer. It would be interesting to find out.
      Jerry
      • bmh
        • Feb 2007
        • 901
        Curios, does the cast iron version share the same casting number as the aluminum ones?
        Brian Howard AMCA#5866
        • Carl Olsen
          • Jan 2002
          • 261
          That's easy, they are factory replacements for 48-52 hudralic pushrod engines. I have done a few engines with these style of lifter blocks and had some throughout the years, including rear ones. Think on the same lines as late knuckleheads with a small port, the factory made the replacement parts from the same casting as the current production parts.
          Carl
          • koanes
            • Apr 2003
            • 656
            Carl, the blocks we are discussing are not later style castings without oil feed holes, they are from the same pattern as their aluminum counterparts.
            • koanes
              • Apr 2003
              • 656
              The front is iron, rear aluminum on this 48.
