'48 Exhaust Spigot Dia?
  • wideglide38
    • Jul 2008
    • 656
    My 48 is leaking slightly around both exhaust spigots and am looking for a fairly reliable fix without tearing her down and having new spigots welded in. I have one idea which is using a 1"W feeler gauge stock and wrap the spigot before sliding the header on. Does anyone know what the factory outside diameter of the exhaust spigots are? Is there a high-temp flexible sealant that can be applied over the spigot with good results?
    Thanks, William
    #10035
    William Edwards, AMCA #10035
    The only real fix is the replace the spigots. Anything else is simply patchwork. I had mine done by Joe at Williams Motors. Joe only does engine rebuilding and related jobs these days. He is trying to scale down in his golden years. An excellant job that looks like nothing has been done since it left the MoCo. UPS goes to his door.
    Willaims Motors
    (661) 466-6479
    • wideglide38
      • Jul 2008
      • 656
      Thank you Chris. Sounds like I have a winter project!
      • krb
        • Oct 2004
        • 16
        header spigot
        beer can material has worked well on both my 50 and 62 as a matter of fact the 50 has had it on the front pipe for 8 yrs or so
