panhead manual
  • 65eglide
    • Jul 2007
    • 62
    panhead manual
    any good manuals out there on rebuilding a panhead , just wanted to see whats going to be involved in this when they do it
    thanks
  • Rooster
    • Mar 2009
    • 543
    Bruce Palmer III's book, "How To Restore Your Harley-Davidson" has an extensive section on motor work, as well as all other parts of the motorcycle.
    • 65eglide
      • Jul 2007
      • 62
      thanks
      I'll check it out
        Panhead Service Manual compiled by T. A. Noel.
          • Feb 2003
          • 5353
          If you want a quick look at things, try registering on http://www.hydra-glide.com/index.php Once you've done that click on the knowledge base and you will likely find most of the info you need from the Panhead Manual.
          Cory Othen
          Membership#10953
          • 65eglide
            • Jul 2007
            • 62
            ok,thanks will check it out
