Protecting Oil Tank Patent Decal
  • wideglide38
    • Jul 2008
    • 656
    I'm looking for suggestions on what I can apply over the patent decal affixed on the oil bag. The last one was unprotected and flaked off due to heated return oil. I want to brush on a clear coat or something to help protect the decal. I want to make sure the coating does not attack or destroy the (water-slide) decal nor yellow from heat, etc. Any ideas?
    William
    #10035
    William Edwards, AMCA #10035
    I would also like an ansewer to this queation. Anyone!
    • bmh
      • Feb 2007
      • 901
      Someone's gonna have to do a science project and buy some decals and try some different seal coats over them on a painted piece of sheet metal and then torture test them. This keeps coming up and that's the only way I know to get an answer. Normally I'm game for something like that but I don't have the time right now.
      Brian Howard AMCA#5866
      • flat-happy
        • May 2009
        • 543
        i cleaned the oil tank with alcohol before applying the decal and it was still perfect when i sold the bike 4 years later and 22000 miles with no coating on it at all. i got the decal from antique cycle supply instead of v-twin. maybe that made the difference. if the tank has any wax at all on it the decal will not stay. even buffing compound.
          In the Panhead days the MoCo used Copal Varnish. Modern folks use transfer cement.
          • wideglide38
            • Jul 2008
            • 656
            Thanks for the suggestions, folks.
            Chris - Is there a particular brand? I goggled Transfer Cement and found 'Heat Transfer Cement or mastic.
            Thanks, William
            • Carl Olsen
              • Jan 2002
              • 261
              We make them out of vinyl that has a clear coat protective covering applied to resist damage from the elements. This is the same material that our "change your luck ride a knuck" and "be a man ride a pan" are made of. They also can have the patina look with the help of a little steel wool.
              Carl
              • vph-d
                • 1088
                I've had good luck using about 5 heavy coats of paste wax, after cleaning the area with laquer thinner.
                VPH-D
                • vph-d
                  • 1088
                  Carl,
                  Speaking of your Pan decals, do you have any idea how my Rio Blue 51 mysteriously received one at the Broken Spoke campground in Sturgis ?
                  VPH-D
                  • wideglide38
                    • Jul 2008
                    • 656
                    Thanks to all for your suggestions! Ride safe!
                    • 48hdbob1
                      • Nov 2009
                      • 111
                      48hdbob1
                      William
                      #10035
                      Clean the surface with prep-sol and it will stay on. Have had them on a '64 FLH rider for 7 years now and alot of miles and no problem.
