Sealing Gas Shutoff Base & Crossover Line
  • wideglide38
    • Jul 2008
    • 656
    I'm trying to fix a small leak at the base of the gas shutoff rod where the cross-over ties in on my 48 pan. I've cleaned everything thoroughly, installed new brass washers, etc. I was wondering if anyone has coated the brass washers (both sides) with a TFE (chemical & gas resistant) paste with any success. The shutoff rod is aligned - no leaks when shut. Any suggestions?
    William #10035
    William Edwards, AMCA #10035
    William!
    The copper crushwashers used for the carburetor bowlstem are far more forgiving than the brass washers.
    Try 'em you'll like them,
    • wideglide38
      • Jul 2008
      • 656
      Cotten,
      That's a very good idea, thanks! I just reassembled the rod seat and crossover . . if she leaks again she'll get the crushwasher treatment!
      Ride safe,
      William
        Could it be the joint on the fuel crossover line that is leaking?
        • wideglide38
          • Jul 2008
          • 656
          Chris, I checked the joint during re-assembly. The joint looks solid & tight. Plus it didn't leak over night! Thanks
            • 6039
            I wrap the brass washers with teflon tape. In and out until I have a good build-up of teflon tape. I have been doing this for many years on every early big twin with cross-over lines and never. . . Repeat, never had a leak.
            • wideglide38
              • Jul 2008
              • 656
              Eric, Thanks for another great solution! Should have scratched my brain longer . . . and I do have some gas resistant teflon tape (yellow)! Ride safe, William #10035
              • Carl Olsen
                • Jan 2002
                • 261
                I make them out of PEEK, they never leak and are reusable, same with the carb bowl seal and the seat for the needle valve on the carb bowl. You have to be crative with all of that core material when you are paying lots of money for the solid tube just to make manifold seals. I even used it for a worn out axle sleeve on the garden tractor.
                Carl
                • cdndewey
                  • Jan 2005
                  • 438
                  Carl
                  What the heck is PEEK?
                  • rwrun
                    • Mar 2005
                    • 59
                    polyaryletheretherketone
                    or a thermoplastic material typically found in sheet or rod stock
                    Rich
                    AMCA #8438
                    • Barry
                      • 21
                      Now that we know the chemical makeup, would someone please explain what it is and how to use it. And where do you get it. Barry
                      Barry E Porter
                      • rwrun
                        • Mar 2005
                        • 59
                        PEEK is a plastic material which can be machined to whatever specifications you would like. I have gotten it from Curbell Plastics in the past for applications other that motorcycle parts.
                        Link Below
                        http://www.curbellplastics.com/engin...tics/peek.html
                        Rich
                        AMCA #8438
