Before I start searcjing I'll start asking
  • Magic
    Magic
    • Dec 2002
    • 282
    Hey guys before I start taking too much apart on my 1965 FLH I'll ask of others experiences with my problem. My battery was getting old and when I tried to start it this Spring it didn't have enough power to turn the engine over even after a few slow kicks to loosen her up. ( I do use Battery tenders) It did start however and I used a jumper cable on it to encourage it to start with a booster charger. I purchased a new battery for it and upon connecting the battery there was an arc and draw of power with the ignition switch off. It was more than a little arc so I never connected it. My first thought is the ignition switch itself... The power arc drawn was significant as to use of the electric starter however it didn't engage. Curious as to the thoughts on something that was fine before and now a new battery arcs when connecting it? Thanks in advance for any and all suggestions made. I'm busy doing non-Motorcycle activities that I'm swamped with work. Merlin in Pa.
  • portagepan
    • Feb 2006
    • 580
    I would probably get the wiring diagram, and diconnect the positive wire to the switch, then try it again. I am no expert, so I know that having a diagram and recording each check, and being thorough is the only way to go. If it did it with the switch in the off position, that says something.
    Mike
    • Rooster
      • Mar 2009
      • 543
      I'd say to look at the starter solonoid switch. They need to be taken apart and cleaned up and lubed every so often.
      • Magic
        Magic
        • Dec 2002
        • 282
        Thanks 4 the replies before my fingers get dirty
        Thank you for the reply and I do believe you're right. I still haven't had time to look into it more and that's the area I'm going to head into. Sad thing is I've only riden one of my Motorcycles in the last 2 months :-( I get sidetracked and put too much workload on myself and need to take a few days and go. I think next week I'll put that one on the lift and look into the Solonoid and get it up and running again. Merlin in Pa.
        • Rooster
          • Mar 2009
          • 543
          Originally posted by Magic View Post
          Sad thing is I've only riden one of my Motorcycles in the last 2 months :-( I get sidetracked and put too much workload on myself and need to take a few days and go.)
          Priorities, Man! Priorities!
          • JSB55
            • May 2009
            • 332
            At last a question a "newbie" can answer!
            The solenoid always has power to one side, and the starter button engages it by grounding and completing the circuit. The main ignition switch interrupts the grounding when it is in the off position, and allows it when "on".
            The two most likely causes of the condition described would be the wires to the starter button itself allowing a contact to ground *before* they get to the main ignition switch or the solenoid being partially mechanically engaged and somehow grounding the circuit itself.
            The latter seems unlikely, but is possible, which is why you should never open the primary cover without disconnecting the battery ground cable, eliminating the possibility you'll accidentally ground the solenoid and engage the starter while your fingers are in the mix.
            P.S. -- all of the above assumes that you're saying the bike tried to start when you went to connect the battery. If it's just an arc, then either the positive battery cable is grounding out (e.g., worn insulation somewhere allowing contact to bare metal between the battery and the main switch) or the main switch is broken and not disconnecting the circuits when you turn it "off". Ordinarily you'd connect the positive cable first, and then the negative, and nothing happens because the ignition switch being "off" is interrupting the completion of the connection of the entire circuit back to ground.
            Ride it like you can fix it!
              • 4778
              JSB55,
              You are missing the mechanical aspect of it. The most common cause of solenoid sticking isn't the electrical part. It is a jammed starter drive locked to the ring gear which in turn keeps the contacts connected in the solenoid. The solenoid can also be full of oily gunk and the piston is stuck. Common on all kinds of vehicles and usually caused when trying to start with a low battery. I have seen it on everything from lawn mowers to trucks. Often just rocking the vehicle in gear releases it and once the battery is charged all is good.
              Robbie
              • JSB55
                • May 2009
                • 332
                Which is what I meant by "the solenoid being partially mechanically engaged", but you definitely clarified how that can happen!
                • Magic
                  Magic
                  • Dec 2002
                  • 282
                  Thanks Rub as well as everyone else that offered logical advice. This Motorcycle was parked in and finally went for a nice summer evening ride when it cooling down out there LOL Yes it needed a rocking in gear and that did the trick. I like this motorcycle alot and just ignored it for too long :-/ I hope tonite is just as nice as last night :-) Merlin in Pa.
                  • Underdoggie
                    • Mar 2009
                    • 100
                    Back in 89 when my 65fl still had a virgin wiring system I had a problem one hot day. When I turned off the ignition, the wiring around the key switch started to burn, like there was a short. When I turned the key back on, it stopped. The problem turned out to be the neutral switch. It is a two wire switch that is right in the starter circuit. Mine had shorted out to ground.
                    If yours is that way it would have caused the sparks when you tried to hook up a new battery.
                    My bike has a cross over exhaust and that switch is right under the pipe, I think over the years it just got hot one too many times and the bakelite or whatever the insulator is made out of just failed. I still have the switch, it had some really strange connectors with some little wire retainers.
                    After I replaced the switch, everything was fine again, plus I added a main breaker and a relay like the factory bulletins called for.
                    Might be worth checking out.
                    Underdoggie
                    John Underwood
                    AMCA#14400
                    Central Illinois
                      • 5948
                      Or flip the disc over.
                      • Magic
                        Magic
                        • Dec 2002
                        • 282
                        More good advice being offered... Thanks
                        Thanks for the professional advice on this matter and I will ...when I get the chance again LOL Go at the Solenoid and clean it lub it. I'm more into the Hydra/Duo-Glides and this is another good learning experience for me. Merlin in Pa.
                        • rbenash
                          • Jul 2001
                          • 643
                          Looks like everyone has chimed in with good advice. As for me - never had this problem on my '65, but did have it on my first year Goldwing. Solenoid plunger was stuck after 85k miles (yes, all mine). Simply had to disassemble and lubricate and all was fine.
                          The characteristic was as soon as the ignition was turned on the starter motor was running.
                          Ray
                          AMCA #7140
