Originally posted by Rooster
View Post
Since I was going through all my frame notes, I thought I would point out that very late 51frames and 52 frames have a unique front motor mount. it is similar to the earlier one except that the valley formed on top has been filled in. I believe this was replaced in53 with the same mount used from then on with a solid mounting pad rather than the hockey pucks. The late 51 frames did not use the new top mount introduced in 52. Sadly these features do not photograph well on assembeled machines so all I have are my notes to go on.
