P/N 56128-50 Vs. 56129-50 question...
  • whtaxl
    • Mar 2009
    • 34
    Hi, Does anybody knows what is the difference between the two part numbers? It is supposed to be a top tree for an adjuijustable rake fork. Parts book does not recognize the 56128-50, only the 56129-50... I wonder what the !#@$%^ is the difference????
    Help anyone?
    Ran
    Where did you come up with the 56128-50 number?
    • whtaxl
      • Mar 2009
      • 34
      Hi Chris, I have the part right in front of me.... I notices the three little holes in the back of the stem holes are located to the side (??) I have pictures, but I do not know how to insert them..
        • 4790
        Are you looking at a number on the part? If so that is NOT the part number for the item as listed in the parts books. It is a number assigned when the part was designed and is in the casting mold. The three small holes by the stem are alternate positions for the bottom locking plate for the steering damper to allow it to lock the upper head cone adjusting collar in place when one of the notches lines up below one of the holes. It may need slight adjustment one way or the other to line up.
        Robbie
          • 4790
          I just went out and looked at mine and it has the casting number 56128-50, which is part # 56129-50 in the books!
          Robbie
            Robbie nailed it.
            • whtaxl
              • Mar 2009
              • 34
              WOW Robbie!! thank you very much! you guys sure know your stuff....
              Regards,
              Ran
