Oil filter fitting Duo-Glide
  • Pandit
    • Mar 2008
    • 34
    Hello
    I will install an oilfilter on my '61 Duo-Glide. Now I'm not sure whitch fitting is correct.
    1: pump: flared fitting? What #No has the fitting to the oilpump?
    2: filter on pump side: is there a flared fitting or rubber sealed?
    3: filter on tank side: is there a flared fitting or rubber sealed?
    4: tank: is there a flared fitting or rubber sealed?
    Thanks for your help.
    Roland
    #13580
  • Pandit
    • Mar 2008
    • 34
    Does no one know the correct fittings for the oil filter?
    Roland
    #13580
    • bmh
      • Feb 2007
      • 901
      Photos in palmers book at the back showlots of 58 & up pans with filters installed.
      Brian Howard AMCA#5866
          • 4790
          Pandit,
          From your pictures:
          #1, fitting shown is correct but oil line is not. You can use that oil line but you need to use the flare fitting already on your pump.
          #2 The correct fitting is the one not connected to the filter.
          #3 See #2 above
          #4 hard to tell but it looks like the correct fitting. It should have the matching flare in one end to fit your oil tank and the other end fits the bushing nut for the rubber bushing.
          Robbie
          • Pandit
            • Mar 2008
            • 34
            Thank you very much for the answers!
