Star Hubs
  • portagepan
    • Feb 2006
    • 580
    Star Hubs
    I have two stepped star hubs for my 1965 HD FLH. One has the spot welds for the jig, and one does not. Were all the original stepped hubs spot welded to hold position while being brazed? I have stripped them both and besides one not having the the spot welds, they look identical, down to the style and kind of brazing. I need to knnow before they are loaded and laced. thanks. Mike
    • 4790
    Stepped hubs?? The step hubs are pre'40 type and not nearly strong enough for your '65 application. Don't lace them to your rims. Trade or sell them and get the correct ones and save yourself a headache, figuratively and literally!
    Robbie
    • Paps
      • Jun 2003
      • 1814
      Mike...My buddy Ron could probably use one of them. Paps
      • portagepan
        • Feb 2006
        • 580
        I guess I didn't say that right. These are just flat in the middle with the two ends attached. I thought that meant stepped. Now can I get an answer? Thanks. Mike
          I am on the road with out Bruce's book with me. He describes, in detail, which hubs go on what years. How To Restore Your Harley-Davidson by Bruce Palmer III
          • portagepan
            • Feb 2006
            • 580
            Thanks Chris. I checked the book. I definitely have the right hub. I was just wondering if there is a way to tell if they are original. They look like it. I see now that both are spot welded, then brazed. One has the sloppy spot welds on the inner edge of the flange, and the other has nice, neat spots centered on the flange. I suppose they are both original, but for all the work and mibney it takes, and the time I am putting into this set of wheels, I sure want to get it right. And I am no expert. I bought these completely empty, with no works. I got that all from V-twin. And now I read that there is no guarantee on the fit. Oh well, I will work that out when I come to it. These both look excellent, with little or no use, but I haven't checked the measuremens.
            Mike
            • vph-d
              • 1088
              I believe a 65 would have the last style of star hubs. On the last style, the spoke flanges are not identical. The brake side is more angular. I have thought this was something to do with juice brakes.
              VPH-D
                • 4790
                VPH-D
                The last style of hubs is for '67 to '72 models and use brake drums that carry the bearings on one side and have a single ball/thrust bearing within and a screw on end cap similar to a Sportster hub. '65 hubs are still the early loose roller type.
                Robbie
                • vph-d
                  • 1088
                  Rub,
                  Sorry, I should have been more clear, the last style of the loose roller star hubs have the different spoke flanges.
                  VPH-D
                  • portagepan
                    • Feb 2006
                    • 580
                    Thanks for the response. But my question was, how to tell if they are oem, or aftermarket.
                    If there is a difference. Mike
                    • rbenash
                      • Jul 2001
                      • 643
                      Mine are stipped an repainted right now, going to try to get some detail photos. I know these are the originals. Don't know if that will help you or not.
                      Ray
                      AMCA #7140
                        Generally speaking, the aftermarkets are chrome.
                        • D.Mac
                          • Feb 2007
                          • 240
                          Repro Hubs and parts
                          Not to hi-jack the thread, but I see that 45 Parts Depot has repro hubs and parts, European made. I have not seen or used any of these, but 45 Parts Depot seems to have a good Reputation. (anyone here used thier hubs or hub parts?)The only way to stop having the tiwan crap dumped on us is to buy elsewhere whenever possible. May cost more, but the cheap crap is cheap because it's crap.
                          Doug.
                          Doug McLaughlin #6607
                          NorCal, USA
                          • nuklhd
                            • Jan 2009
                            • 54
                            d.mac, i laced up a rim using one of kurts hubs. i havn't used it on the road yet but every thing i've bought thru him has been very good quality and he's very helpful and went out of his way to help me.
