Clutch Replacement
  • t-jacobs
    • Jan 2008
    • 130
    Clutch Replacement
    Hi all,
    I am going to replace the clutch plates and clutch hub on my 64 FLH. I have NOS clutch plates and hub in hand. This is my first time. I have done a lot of reading and I am ready to take the job on. I can not find info on the torque for the compensator sprocket nut and the clutch hub nut. Is there a set torque for these nuts or just very tight in general?
    Thanks for any info.
  • Rooster
    • Mar 2009
    • 543
    If you haven't already, you'll need to fabricate a 'jam bar'. This is simply a means to hold the motor or transmission from turning while you tighten or loosen the nuts.
    Remember, there are only two left-hand threaded nuts on a Harley; both at the transmission.
    There's a pretty good Torque Table in the 1970-78 Shovelhead Manual. Says the engine sprocket nut gets tightened at 170 ft/lbs, and the clutch hub nut at 50-60. Since the clutch is virtually the same, I'd go with that, but might back off the engine sprocket to 150 ft/lbs.
    Here's a rough sketch of the jam bar. Position the bar to resist the pressures you put against it, whether it be for tightening or loosening.
    • bmh
      • Feb 2007
      • 901
      I don't think the jamb bar is going work for the clutch, you need to remove the pressure plate to get at the hub nut. without pressure on the discs the hub will spin free of the basket, so holding the sprockets does you nothing. If you take an old wore out lined disc and bolt or weld a piece of flat or bar stock as a handle to it you can slip that over the studs and use that to hold the hub while you tighten or loosen the hub nut with a socket. Of course if the trans is still in the bike you can put her in gear and get someone to stand on the rear brakes. For the motor sprocket I use a wooden wedge and feed it between the sprocket and chain in the correct direction to hold it for removal and install. J&P and others sell stepped Teflon blocks to do the same thing.
      Brian Howard AMCA#5866
        • 4790
        I personally don't like the trans in gear method. Nothing like a tooth broken off a gear to spoil your day! Make a clutch hub holder, it is cheap and easy. And don't go crazy on the clutch nut, it is left handed and if overtightened can split the hub through the keyway, or strip the mainshaft, neither one a desirable result!
        Robbie
        • Rooster
          • Mar 2009
          • 543
          Correct you are on the hub nut! My mistake.
          Just a few weeks ago I fabbed a couple of those tools, an old disk with a chunk of flat stock welded on as a handle.
          But after that task has been achieved, the jam bar will come in handy for the engine sprocket. I can't figure out why anyone would risk stretching or damaging a chain by cramming something in it like that. Once you try a jam bar, you'll never use any of those other devices. J&P? Really? You buy stuff there?
          • t-jacobs
            • Jan 2008
            • 130
            Clutch replacement
            Thanks for the info guys. i have already made a clutch hub holder tool. Rooster when you refer to 150 or 170 lbs for the engine sprocket does that hold the same for the compensator sprocket or did you mean to say compensator sprocket?
            • Rooster
              • Mar 2009
              • 543
              Hmmmm.... that value would probably be correct for an engine sprocket nut, on the inside of the flywheel. Let me get back to you, I'm looking around, and I'll ask some people I know. I'd be careful not to over-tighten, for sure.
              • Rooster
                • Mar 2009
                • 543
                I looked in several different manuals, and the only value I could find was for a mid-80's belt drive model. That torque value is 80-100 ft/lbs. In the 1959-69 manual, it tells how to remove the compensator sprocket nut with several sharp blows with a hammer. But nowhere in the text does it tell you the torque setting upon reinstallation.
                Unless someone can give you a difinitive answer, I'd say anywhere from 100-120 pounds would be good (be sure to use Loctite thread-locker). My motorhead buddy says that's one of the nuts that just doesn't seem to have a value. He sets his at "damn tight".
                • motorhead1
                  • Dec 2006
                  • 171
                  The compensator sprocket IS the engine sprocket.
                  Ride 'em. Don't hide 'em.
                  Dan #6938 FUBO
                  • Rooster
                    • Mar 2009
                    • 543
                    That's right. And the sprocket shaft nut is what holds the shaft to the flywheel. It tightens to 150-170.
                    • bmh
                      • Feb 2007
                      • 901
                      Wow, if you can stretch a double row diamond chain with a torque wrench I'll pay your stakes in the arm wrestling championships and we can make some money. Yet you never seem to consider the effect a jamb bar could have on bending sprocket teeth? Would seem much easier to bend teeth than stretch a chain to me. Besides the wedge method is the one described and used in all modern H-D service manuals, not a locking bar (Primary Drive Locking Tool, part# HD41214). As for J&P? I have purchased from them in the past and most likely will again in the future. Why wouldn't I? After all John Parham is not only an antique motorcycle enthusiast, the primary sponsor of the National Motorcycle Museum in Animosa Iowa, but last I knew was also a member of this club so please tell me again why I should boycot his buissiness?
                        • 6039
                        In no way am I questioning the torque values of various clutch and engine sprocket nuts, but I do wonder how a wimp like me is going to pull 150-170 ft/lbs. on a motorcycle. I could do it on a bulldozer or some other multi-ton object because you have the weight of the object for stability. I've tried pulling high torque weights on flywheels that I have assembled and trued and I end up dragging the work bench all over the shop. I know some people cheat and use a pneumatic impact gun to tighten sprocket nuts, however a friend of mine did that on a late model Chief and pulled the engine sprocket nut so tight it bound up the engine. I wouldn't have thought you could deform hardend steel tapers and thrust washers to that degree. Anyhow, I'm just curious how other people pull high torques on bikes that are still on their wheels without some NFL linebacker holding the bike.
                        • Rooster
                          • Mar 2009
                          • 543
                          You can sure read a lot of stuff into a post that was never said...!
                          • Rooster
                            • Mar 2009
                            • 543
                            "Bending sprocket teeth"? You're not serious. It's obvious to me you've never tried the jam bar, so why would you have an opinion on something you've never tried and really know nothing about?
                            Now ask yourself this--- which is the first to fail, the chain or 'bent teeth' on the sprockets?
                            Naaa... never mind, don't think about it.
                              A folded up shop towel between the chain and the clutch sprocket works if yer in a bind.
