Foot Clutch measurements
  • Rooster
    • Mar 2009
    • 543
    Originally posted by Perry Ruiter View Post
    Most definitely not the one ending with a -65 part number.
    Ahhh.... you mean the one that you showed?
      • 6039
      I have 2 that are similar to the one in question and one that has a pronounced spring mounting feature. Hopefully the picture will come through.
      • cdndewey
        • Jan 2005
        • 438
        Scoot...Looking at your assembled picture it doesn't look like anything is missing to me. However when I look at it and then look at my 62 I see a difference in the area where the spring attaches. Mine is flatter in front leading up to the spring whereas yours has a pronounced slope down. Also the offset looks like it might be a little greater than mine although it is hard to ascertain from the picture.
        • Rooster
          • Mar 2009
          • 543
          These are the two distinctly different 'shapes' that I refer to. I also have the exact same collection as you, exeric.
            • 6039
            Being a stamped part, you'll never know the change-over date unless it was documented in a service bulletin or it had some profound change that gave the part a new part #, or through observation of original bikes, there is a change-over date. Who knows ? The original tool and die could have worn out or broke, or the head of engineering didn't like the original shape.
            • Rooster
              • Mar 2009
              • 543
              Yes.... another example of some of the strange things the MoCo did. The copy of a factory photo I am lucky enough to have, shows the little 'tab' area for the spring. So that much I am fairly certain that is correct for a '52.
              • vph-d
                • 1088
                That clutch pedal is in awfully good shape, is it a V-Twin repop?
                VPH-D
                • Rooster
                  • Mar 2009
                  • 543
                  The most recognizable feature of as repop is the weld on the end of the pivot shaft. OE parts have a nice circular weld, like you see in Scoot's photo, while repops have a full button-looking weld. At least that's what I've seen...........
                  • vph-d
                    • 1088
                    I pulled out 2 foot pedals and found neither one has a welded pin, both are peened with a distinct button head look. Both pedals also have a taller nerd for the spring, than in the first pictures. I recently replaced the clutch pull rod pivot stud on one of my pedals with a NOS pin. The original pin had a button look, and so does the replacement pin, unlike the first pictures. I think the pedal is repop.
                    VPH-D
