Pan Tansmission Case #
  • wideglide38
    • Jul 2008
    • 656
    I need some help identifying a Pan transmission I came across this weekend. Was told it is off a '52 Pan. I think later. The case is identified with the following casting marks: '121 35' and *33* on the bottom. The vent plug boss is not drilled (as in '56 & later). I've looked through Palmer's book to no avail. Any words of wisdom? Thanks, William Edwards AMCA #10035
    William Edwards, AMCA #10035
  • vph-d
    • 1084
    If the vent boss is not drilled, the case is for a 56-64 model.
    VPH-D
    • vph-d
      • 1084
      VPH-D
      • wideglide38
        • Jul 2008
        • 656
        Thank you! As I suspected.
          • 2017
          I have a case identical to it. There are alot of those case with the 3-3 casting which meant that HD was sitting on this case for well over a year before it got machined. Times must have been slow.
          Jerry
          • wideglide38
            • Jul 2008
            • 656
            Thank you Jerry!
