lifter base needed
  • Glenn
    Member to Remember
    • May 2007
    • 403
    lifter base needed
    50 pan the rear lifter base has part of the bottom of the base broken off. Anyone have a rear lifter base they want to sell ?
    looks like previous owner put it back together with the broken base. I found no metal inside the block anywhere. Oil pump housing has virtually no marks in it.
    Moose
    aka Glenn
    Glenn, Got cast or aluminum?
    • Glenn
      Member to Remember
      • May 2007
      • 403
      it is aluminum
      Moose
      aka Glenn
        The most common cause for a broken lifter base is from using it to over-tighten the lock nut, instead of putting a second wrench upon the adjustor.
        Many can be weld-repaired.
        • Glenn
          Member to Remember
          • May 2007
          • 403
          the whole underside guide part is broken and not anywhere to be found. The previous owner must have put it together broken. The bike has been sitting since 1964 in the second owners garage.
          Hope someone has one burried somewhere they would sell. Everything else in the motor other than the cam is in good shape.
          Moose
          aka Glenn
            Glenn you got a message.
            • koanes
              • Apr 2003
              • 656
              I have a cast iron rear block I have been trying to find a mate for, going on 25 yrs. I have held other rear blocks but have never seen a front. Does anyone have timeline for the use of the iron blocks?
              Kyle Oanes AMCA # 3046
              • Glenn
                Member to Remember
                • May 2007
                • 403
                thanks guys found a set of aluminum block from robert above thanks for all you efforts
                glenn
                Moose
                aka Glenn
                • bmh
                  • Feb 2007
                  • 901
                  Cotton, The original solid tappets as used with the aluminum blocks do not have flats on the body to hold with a wrench when tightening jamb nuts. I will adjust the pushrod and then roll the motor foward to put pressure from the valve springs on the tappet to help hold it and take some stress off the ears on the block. As long as you are runnning the stock pushrods with the hydraulic units up top any slight movement on the adjustment wont really matter. Solids on the other hand may need some fine tuning re-adjustments to get just right. This also helps avoid dinging up the top edge of the blocks with the wrench that you see on so many aluminum blocks.
                  Brian Howard AMCA#5866
