fork lock
  • Glenn
    Member to Remember
    • May 2007
    • 403
    fork lock
    somewhere i found the method of removing the fork lock on my 50 pan head frame and for the life of me I don't remember where.
    anyone know I really cant see where the pin is that holds it
    Moose
    aka Glenn
  • Magic
    Magic
    • Dec 2002
    • 282
    remove all the paint
    Hey Glenn, I believe the pin is at a 1-2 o'clock position straight into the side of the lock casting as you look at the lock face. Removing all the paint in the area is necessary to locate it as the excess was chiseled off after inserted about 1/2 inch back from the front of the lock. I'm sure you have your frame stripped by now of the front fork tree assembly which makes it easier yet to work in that area. The lock mechanism itself will undoubtably be stuck in place and a key inserted to wiggle it out is often necessary along with plenty of penatrating fluid. Merlin in Pa.
    • Glenn
      Member to Remember
      • May 2007
      • 403
      thanks merlin
      i thought all that stuff was on the panhead flathead site but I cant find it
      Moose
      aka Glenn
        The pin is in that location. The easiest way to remove it it to have a very good welder weld a blob on the top of the pin. Let some Aerokroil soak in then grab the blob with a pair of vicegrips and pull out the pin.
          I use a left-hand drill, carefully, as it always appeared to me to be a screw that had the head chiseled off. Some later models used rollpins, which are very hard to drill.
          Wiggling the core with a key helps you feel for when it is loose, and helps to avoid drilling into it.
          After replacement of the lock, I tap the hole for a #6 setscrew, and fill it with paint.
          • Glenn
            Member to Remember
            • May 2007
            • 403
            thanks for all the info
            as I progress I'm sure I'll have tons of questions, hope you folks don't mind but I figure I'd rather do it right the first time and although it wont be a 100 per cent I want the best I could do with mostly my own hands
            moose
            Moose
            aka Glenn
            • Glenn
              Member to Remember
              • May 2007
              • 403
              wound up cleaning the lock off with carb cleaner and was able to read the numbers. went to the local locksmithy and they made a key from the code and it worked.
              Moose
              aka Glenn
