Can anyone tell me what the ohmmatic ranges are for the coil's primary and secondary? I've looked through service manual & can find no reference. My coil is p/n 31604-48. Thanks!
Coil Resistance
Coil Resistance
http://www.amcasouthernnationalmeet.com/Tags: None
I get about 1 ohm across the primary and 3.4k across the secondary. There should be infinite resistance between the primary, the secondary, and ground. Unlike a car coil, the primary and secondary windings aren't connected to each other.
Thanks TimWilliam Edwards, AMCA #10035
