oil gusher.
  • portagepan
    • Feb 2006
    • 580
    oil gusher.
    Went for my 2nd ride on my newly rebuilt '65 FLH today, after sorting some carb issues. The ist ride yesterday, after some run in time on the bench was 8 miles, and went good, except for the carb problem. After a 20 mile ride today, things seemed good. Came back out to tighten something and found a nightmare. It had puked a whole bunch of oil out the breather. I retraced my route, and this was going on for miles. No other oil leaks. So what the hey?? HELP!!!!!!
    Mike
  • portagepan
    • Feb 2006
    • 580
    Also, this didn't happen when it was started, so I don't think it would be the check ball. It was still pumpimg oil back to the tank after this, so at least I don't think my brand spankin' rebuilt motor got hurt. And I really did want to get it over to Wauseon this weekend for Panhead days. This sucks!
    Mike
    • bmh
      • Feb 2007
      • 901
      does your 65 have the rear chain oiler? If so what is the adjustment? if I remember right the chain oiler hose and the motor vent are the same. This would most likely only pump out oil once the RPMs picked up.
      Brian
      Brian Howard AMCA#5866
      • portagepan
        • Feb 2006
        • 580
        Something in the oil pump is working intermittently.
        Mike
          Mike!
          A sheared key can catch and slip intermittently;
          Sounds like it is on the return side.
          Good luck,
          • portagepan
            • Feb 2006
            • 580
            Just to wrap this up. The oil pump gasket had broken on installation, and just let oil go haywire inside the motor. Replaced it, and I have 500 miles on it now, and it seems OK. You just never know, until you take it apart sometimes.
            Mike
