aluminum pushrod covers
  • jorrow
    • Feb 2008
    • 347
    In the restoration of my 1963 and 1965 panhead I had noticed that the valve covers were an anodized aluminum. It allowed the user to forego polishing upkeep and maintained a shimmery appearance. However it scratches very easily and cannot be polished back once this happens. But what few people realize and you hardley ever see on a restored bike of this era is the anodized aluminum pushrod covers. I am curious as to when they were actuallly introduced. If they started with the pan valve covers it was probably 1958? Does anyone have any insight to these? Most became very ugly as they were scratched resulting in people throwing them away and replacing them with chrome covers right away. Over time habit tends to result in the "new" standard. Does anyone remember?
  • Kris H
    • May 2006
    • 22
    Anodized pushrod covers
    I just finished the restoration of my 1962 FLH before the Eustis, FL meet and one of the hardest pieces to find were aluminum pushrod covers in good enough shape to restore. A friend in Illinois found a set and sent them to me and I found a local anodizer who could match the finish exactly. I also had the pan covers done at the same time and match perfectly. It was not cheap, but well worth it. I will try to post a few pictures and maybe some video if I can figure it out.
    • jorrow
      • Feb 2008
      • 347
      Thanks for the info Kris, I'm glad I'm not alone in this dilemma. Jeff
      • Kris H
        • May 2006
        • 22
        Hi Jeff, I just tried to up load a picture and was told it was to big, I will take a few more at a lower setting and some video and try again!
        • rick anderson
          • Dec 2006
          • 63
          anodized aluminum valve covers
          Hey, can I get the name of the anodizer who did the valve covers or any other anodizer who can do the job correctly?
          Thanks, Rick.
          Rick Anderson
          • Kris H
            • May 2006
            • 22
            here is a picture of the pan covers that match the pushrod covers.
            • Kris H
              • May 2006
              • 22
              finally, a picture that was small enough!
              • rick anderson
                • Dec 2006
                • 63
                Pan covers
                QUOTE=rick anderson;66666]Hey, can I get the name of the anodizer who did the valve covers or any other anodizer who can do the job correctly?
                Thanks, Rick.
                Rick Anderson
                • Kris H
                  • May 2006
                  • 22
                  Aluminum Pushrod Covers
                  Hi Rick, I will dig through my paperwork when I get a day off and talk to the plater to see if he would like more business. You would think he would!!
                  Kris
                  • Kris H
                    • May 2006
                    • 22
                    Hi Rick,
                    I finally got by to the plater yesterday and asked if he would mind if I posted his info and he said that would be great. He also has a web site to go to. It is www.melimarfinishing.com.
                    His name is Manfred Rosenow. Make sure you mention the AMCA when you talk to him. The process I used is Clear Anodizing. You can send your parts already polished or he can polish them, it is up to you.
                    I hope this helps you and anyone else looking for this.
                    Kris
                    Ps. His phone is 954-327-5788.
                    • rbenash
                      • Jul 2001
                      • 643
                      So what's proper for pushrod covers? What years were anodized and which were chrome? Or were they all anodized as stock? My 65 has chrome pushrod covers. The rocker covers look anodized.
                      Ray
                      AMCA #7140
                      • jorrow
                        • Feb 2008
                        • 347
                        All very good questions, and an excellent research subject. The parts books dont seem to mention the material....but since the tubes scratched so quickly from maintainance they may have become an eyesore and were discarded earlier than the pans...i have noticed that you see more of the pan covers at the swap meets than aluminum tubes....and you would think that you might see a glutton of them if they werent pretty and made all those years...jeff
                          • 8234
                          Can we nail down the exact years for aluminum pushrod covers?
                          TIA,
