Pan Cylinder Head Remanufacturing
  • k.perry
    From V-Twin. Done in sets. Heads must be in rebuildable condition. Installs no-lead seats, cast iron guides, valves, springs, collars and keepers. For stock lift cams only. '48-65 Pans (VT 11-9050) 10 day turnaround.
    Accurate Engineering (334) 702-1993, is where to send your heads if they need fin work, or exhaust spigots rebuilt. Accurate runs weld-beads side-by-side around the spigots to build them up and then machines them back to original specs, without removing the original spigots and losing their degree of position. Know your cam size for valve overlap calculations...they'll ask.
