Clutch hub stud replacement.
  • rick anderson
    I'm replacing the studs on my clutch hub, any suggestions or "do's or don'ts" when peening the ends of the new studs would be apreciated, I'm going to try installing all of the short pins first, setting the hub face down on the bench,peen ends facing up and peening them over with a pneumatic rivit set, and then do the same for the long studs.
    Rick.
