Front Chain Oiler - Primary
  • Iacovos
    • May 2012
    • 208
    Hello everyone,
    Upon opening the primary of the 1960 FLH we have found a lot of dirt sand etc etc.
    We have done a thorough cleaning and even removed and cleaned all the clutch discs.
    At the same time we have reset the oiler screw on the pump back to factory settings (screwed all the way in and backed it 1 1/4 turns).
    After the first test ride we found a lot of oil coming from the drain pipe after the bike was parked. We did not have so much oil before!
    We screwed another 1/4 turn the oiler screw leaving 1 turn out from bottom but still a lot of oil is coming out (see picture)
    What are we missing here? Thanks
  • dukekleman
    • Jul 2022
    • 596
    Originally posted by Iacovos View Post
    Hello everyone,
    We screwed another 1/4 turn the oiler screw leaving 1 turn out of full but still a lot of oil is coming out (see picture)
    Lacovos,
    You mentioned that you reset the chain oiler...
    Where was the setting at prior to readjusting it?
    I have some answers for you but I'm wondering the baseline setting was first ...
    Duke Kleman
    • Iacovos
      • May 2012
      • 208
      Thanks Duke,
      We found the oiler screw to be about 2 turns out from all the way in.
      So we followed the manual which says to screw all the way in and back out 1 1/4 turn to be at the factory setting (ore or less)
        • 4789
        Keep in mind that the oiler tube is also the exhaust of the crankcase breather system, and any excessive oil in the cases from oil pump leakage (sumping) that cannot be picked up quickly by the return side of the oil pump gets blown into the breather passage and dumped into the primary case. Lots of discussion on this issue which is very common . Do a search and lots of info will come up.
        • Iacovos
          • May 2012
          • 208
          Thanks Rubone and will search the forum for oil sumping as you suggest.
          however this excessive oil spill started after the oiler screw was adjusted.
          Would not that point to the culprit? Or it does not matter?
          thanks
            • 4789
            thanks
            Oiler screw doesn't matter. It just drips a little oil into the passage to be blown onto the chain with crankcase pressure. But any excess oil in the crankcases, (a common issue when engines sit unused for long periods), is collected and also blown out that tube.
            • Iacovos
              • May 2012
              • 208
              Agreed! Just read a few posts after your suggestion Rubone
              In summary should the ball following inspection and cleaning be burnished into the seat with the tool anyhow?
              Will do some more reading on this of course
              Thanks so much
              • dukekleman
                • Jul 2022
                • 596
                Lacovos,
                The metered orifice in the oil pump body will see a reduction in size over time. There is more than one factor that attributes to this reduction.
                Anyhow, when you reset the adjustment screws taper into the metered orifice passage way, you essentially resized the passage way to its original dimensions.
                This is why it now flows more oil at 1 1/4 turns than it was flowing at 2 turns.
                Hope this helps,
                Duke Kleman
                • Iacovos
                  • May 2012
                  • 208
                  Thanks dukekleman
                  • Iacovos
                    • May 2012
                    • 208
                    Think this is FIXED also.
                    Will confirm after a test ride though
                    • Iacovos
                      • May 2012
                      • 208
                      Hello Everyone
                      Doing some searching and reading on sumping (also watching youtube videos) it seems that opinions are divided and there is not a clear methodology
                      Some have light tapped using a pushrod whilst the pump is on the engine and replaced ball and seat
                      Others removed the pump and lapped with a pushrod with the use of a lapping compound
                      Others used a flat grind
                      Surely there must be a favorite amongst the community?? Thanks
                      • otis71
                        • Jul 2015
                        • 597
                        A leaking check valve can be problematic to correct. I’ve had some success tapping with a ball and drift and if that doesn’t help there’s a company in los Angeles called bal-tec that specializes in ball valve seating tools. If you tell them the pump composition and ball size they will set you up with the proper abrasive tool. Lapping compound can change the seat dimension because of the thickness of the compound and potentially will make it worse.
                        • Iacovos
                          • May 2012
                          • 208
                          Thanks otis71
                            • 2034
                            Like valves, a narrow seating surface gives more pounds per square inch of seating pressure on a narrow seat. Burnishing or pounding gives a wider seating area & less pressure per inch. I designed fill valves for industrial bottle fillers, angles of seat & width of seat make a huge difference when you are trying to stop the flow with a clean cutoff & no seepage.
                            • Iacovos
                              • May 2012
                              • 208
                              Noted and thank you duffeycycles
