exhaust system
  • iwa
    • May 2011
    • 6
    exhaust system
    has anyone used either a gasbox or a paughco stock exhaust system for a 52 panhead and which one would be recommended?
  • dukekleman
    • Jul 2022
    • 596
    Iwa,
    I've used them both numerous times on different bike build's.
    I really dis-like an exhaust system that has any leaks in it. It bothers me a lot audibly and changes the fuel system calibration.
    Quite a few times I've blended the Gas Box and Paughco systems together to get the fitment I'm after.
    What I like about the Paughco is the one piece s pipe and y pipe. It eliminates one chance of a exhaust leak and gives more room to tuck it in tight without contacting the crankcase and brake bell crank.
    It's not an entirely original design/look but functionality is more important to me as a rider.
    If the bike was just a static display I would use the entire Gas Box OEM based design.
    Hope this helps,
    Duke Kleman
    • iwa
      • May 2011
      • 6
      Thanks for the info was really helpful
      • otis71
        • Jul 2015
        • 597
        Gasbox has improved the fit over the year. Last one I bought fit without any alterations.
