1959-62 Engine Numbers
  • 1959-62 Engine Numbers
    I know that the sixes and nines on 59-62 FL models used a round back on the year number and a straight back sixes and nines for the sequential numbers. Was there ever a deviation to this? I’ve seen rounded numbers for the sequential number on FL and XL models and wonder if this is a dead giveaway for a restamp?
    My 62 is straight back in the model year and there is one 9 in the serial # which is straight back. Late year high production #, has non drilled outside oil bosses on the heads as well.
    Bob Rice #6738
      My 62 has straight back in the year as well. Serial number 10xxx. Mike
        My concern is rounded sequential numbers
          Straight back 9 on my 1959 in the year
            Here’s what I’ve found thus far.
            In SNs for 59 Pans the year 9 was a certain straight-back type early on but it later changed to a certain round-back type which then seems to have continued for the rest of the 59 model year. The year 5 also changed.
            The sequence 6/9 was a certain straight-back type.
            In SNs for 60 Pans the year 6 was a certain straight-back type early on but it later changed to a certain round-back type which then seems to have continued for the rest of the 60 model year. The year 0 also changed.
            In SNs for 61 Pans the year 6 was a certain straight-back type early on but it later changed to a certain round-back type which then seems to have continued for the rest of the 61 model year. The year 1 also changed.
            In SNs for 62 Pans the year 6 was a certain round-back type early on but it later changed to a certain straight-back type which then seems to have continued for the rest of the 62 model year. The year 2 also changed. NB: both year 2s are different to the sequence 2.
            Originally posted by otis71 View Post
            I've seen rounded numbers for the sequential number on FL and XL models and wonder if this is a dead giveaway for a restamp?
            Can you post partial photos please.
            A round-back 6/9 in the sequence portion of any Pan SN (48–65) usually (always?) indicates a problem.
            But Sportster SNs seem to have used a round-back 6/9 in the sequence portion for 57–61 models and some, not all, 62 models. And in the year portion for 59–61 models and some, not all, 62 models.
            NB: did some 67 Sportster SNs have a round-back 6 in the year portion? I don’t know yet. (A round-back 6 was used in the year portion for some, not all, 67 Shovel SNs and some, not all, 67 Servi-Car SNs.)
            Eric
