I don't have this new project I'm chasing yet but I have questions about it. The 1950 FL has a magneto instead of a distributer. Can I put a voltage regulator on it or do I need a generator. Oh would it be 6 volt or 12? Thanks
New question on Electrical. I hate electrical issues.
John,
A magneto does not produce the power for battery upkeep or lighting needs. It merely makes the spark plugs spark. So yes, the bike needs a generator and voltage regulator along with a battery (unless you want no lights at idle). As to 6 or 12 volt that is determined by the generator. The magneto has no voltage interaction with the rest of the motorcycle just as points and condensers are not voltage specific in a conventional ignition.Robbie Knight Amca #2736
- 1 like
