Starter Housing Identification
  • JSB55
    • May 2009
    • 332
    These two starter housings are nearly identical, and apparently interchangeable, but which is correct?
    The one on the right, with the relief passage at about 4 o'clock was on the Delco Remy starter on my 65 FL. On the left is a spare from my parts collection.
    Clearly I can use either, but which is correct for a Delco Remy starter on a 65?
    Any info appreciated!
    John
    Ride it like you can fix it!
  • vph-d
    • 1088
    The housing on the left is correct for a 65, the slot was addressed in an August 8 1966 Service Bulletin. I'd use the one on the right.
    vph-d
    • JSB55
      • May 2009
      • 332
      Interesting! Thank you vph-d!
      I actually found that service bulletin. Passages intended to drain away any accumulated water.
