65 panhead
  • Shovel81
    • Oct 2024
    • 3
    65 panhead
    I just got a 65 pan back together. It starts but I don't think I have something right. It has the original Linkert M carb and original advance distributor. After it gets warmed up it won't start unless I have choke on. After it starts I can get it to idle. Any ideas?
  • Shovel81
    • Oct 2024
    • 3
    I think I got it. Turned low speed adjustment out more and now it lopes along. It was running really high. I don't work on Linkerts very often
      • 8248
      Lucky you, Shovel81!
      Please beware, a lopeing idle is too slow.
      Please tune mixture for the highest engine response, and then reduce RPM at the throttle bellcrank idle screw.
      Adjusting to a smooth idle will assist lowspeed acceleration, and avoid 'flat spots'.
      PS: When a machine 'lopes and bounces' at reduced idle, it is because it wasn't balanced for stationary duty. Engine wear is at its worst.
      • Shovel81
        • Oct 2024
        • 3
        Thanks for that. I will do it that way. Where the throttle cable hooks up it was hitting frame. I modified the bracket so I have more adjustment. Now to get mousetrap working better.
        • droptopford
          • Jan 2010
          • 361
          Take care! They got that name for a reason.
