Lower pushrod tube footprint
  • 58panman
    Old Member
    • Dec 2010
    • 91
    Well the lower push rod tube leak has finally been stopped! After multiple times trying different corks, EZ lube, springs, shims, and filing cork od down on middle cork to make sure it wasn't sticking on compression. I purchased silicone gaskets and have no leak after about 150 miles. Thanks all for your help. Hope this helps someone. Maybe another set of corks would have worked but done for now.
