48 Panhead – front chain guard mounting - upper/lower – easy question!
  • harleygreg
    • Oct 2018
    • 215
    Hi Guys - The front chain guard is mounted at the rear by using an upper and lower bracket with an assembly of bolt/washer/spring/pin, but how are they arranged and what is the purpose of the spring?
    Is the arrangement I have drawn correct, and if so, is the purpose to allow the components a degree of movement contained by the spring pressure?
    Greg
  • droptopford
    • Jan 2010
    • 360
    I think your diagram looks right. Here is a pic of my '48. Pretty sure it is installed correctly (although could use some GUNK!) 48 CHAINGUARD.jpg
    • harleygreg
      • Oct 2018
      • 215
      Thanks, is the bottom one as per my drawing too?
        • 4786
        Your drawings are correct.
        • otis71
          • Jul 2015
          • 597
          Only tighten the nut enough to get the cotter pin into the bolt to allow for vibration otherwise your inner primary cover will crack.
          • harleygreg
            • Oct 2018
            • 215
            Ah, I see, it’s to allow for vibration, thanks Otis
              • 8234
              Vibration is only part of it, Greg,..
              Rigid frames are spring-tempered to flex; It is the primary suspension.
              The flex focus is right there.
              So it is really a chainguard dampener!
              • harleygreg
                • Oct 2018
                • 215
                Thanks Cotten
