Late 48 Front Fender Tip
  • jgbrown59
    • Jul 2008
    • 83
    Does anyone out there have a template or some type of guidance for the holes to mount this late 48 front fender tip? While I am asking, I also need a template for the rear version of this fender tip.
  • Architect
    • Dec 2014
    • 283
    When I installed one on my '46, I first fitted the trim piece to the fender. Bending it to fit the contour the best I could. I cut a card board template out matching the outside shape of the fender trim. Then I put black marker on the screw bungs and fit the card board to the trim, transferring the bung locations to the card board. Cut holes in the card board and I had a template. Spent a bunch of time fitting it to the fender before I started drilling holes. Blue tape holding it in place, back up, check the location, center etc. Maybe not the best way, but it worked out for me, good luck.
    • jgbrown59
      • Jul 2008
      • 83
      Thanks for the input. I considered similar but didn't want to reinvent if someone had an actual template. I will tackle this and see how it goes.
        • 2044
        If you had a template it probably wouldn't fit ! I do similar to Architect
