Rear Fender Hinge
  • jgbrown59
    • Jul 2008
    • 83
    Rear Fender Hinge
    I am trying to determine the appropriate rear fender hinge configuration for a 48 FL. I have included pictures of fenders where the hinge pin can be removed and fenders where the pin cannot be removed. Which is correct for a 48 FL?
    Did Harley change this configuration, and if so, when? Did this change when the hinge was redesigned in 48? I could not find mention of the pin removability in the Palmer books.
    Late 46/47 fender - can remove pin.
    48 Fender - cannot remove pin - Original fender prepared for paint, correct underneath with the change to wire routing in 48 - open wire channel and flexible tube to span the hinge.
    59 Fender - can remove pin
    Repainted 66 Fender - cannot remove pin
    Original Paint 66 fender - cannot remove pin
    Thanks for the help!
    • 6010
    Great pictures, and documentation. Curious to know if the hinge pin height was an intentional engineering feature, or an assembly problem.
      • 8231
      I remember old-fashioned sand-blasting could sure screw them up, Folks.
      • jgbrown59
        • Jul 2008
        • 83
        Checking in - any more feedback on the correct hinge configuration?
          • 4779
          This NOS is recessed....
          • jgbrown59
            • Jul 2008
            • 83
            Thanks for the reference. Would that happen to be a 48 fender? Any idea why some are recessed and some are not?
              • 5950
              • jgbrown59
                • Jul 2008
                • 83
                Thanks Chris. Still no definitive answer as this one appears to be removable. I wonder if the exposed portion of the hinge was random. At least I'll get to see many examples at Davenport next week.
                  • 6010
                  This is the fender on my '51FL. It was on the bike when I got it (including 20+ drilled holes). The seller got it from the original owner who bought it new from Puckett Motors in Orlando, Florida. It's a 3 rib fender and I believe it is genuine to the bike.
